メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
new fan now spins 100% speed
Hi there I just ordered a new cooling fan and after installation it only spins at 100% speed which is kinda annoying, especially because its a blower style fan and makes alot of noise. Just wondering if there is something i could have done wrong or if the fan itself could be the issue
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Missing a wire/pin, or not plugged in all the way. Probably borked fan.
Why did you replace it to begin with?
Does the laptop run slow? It could be a sensor issue.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is a borked fan. I replaced it because the stock one was on it last leg when it spun up it would make bearing noise plus I have been kinda fixing it up alitle, pulled it apart cleaned it, reapplied thermal paste, new RAM, and went to SSD. But I did all that before I ordered the fan and everything was working like it should. And I have not experienced any slow down, and the app I downloaded to read cpu temps it reading 40-41c which is where it was before but fan speed reads 0rpm.
さんによる
コメントを追加
回答を追加する
mtbskilz さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 5
今までの合計 78
