I can not run when playing cod
when I press down on the left anolog stick when playing cod it wont run and iv only had it six weeks
Take it back to the store, they will replace it. Failing that, call Sony and they will send a new one out.
このアンサーは役に立ちましたか?
I spilled coke on my controller, but i ended up having the same problem as you. All buttons worked fine, but can`t run in COD. Now i`ve tried to disambly the hole controller and cleaned it good with electrical spray and dry cloth. Gonna let it dry for a wile and then try.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 128
Does the Left analog stick work with other games/in general, just not in CoD? Or does it not work, full stop?
james さんによる
