メインコンテンツにスキップ
Wi-Fi, GSMとCDMA モデルのiPad第二世代です。あるモデルはiPad3発売前に改良されたものがあります。修理は困難で、熱で温めてこじ開ける作業が必須です。
Digitizer/Screen keeps popping up after replaced? any help?
I have replaced the screen/digitizer on probably 5 or 6 ipad 2's and on every single one i have replace the most difficult thing is to keep the screen/digitizer glued down, it keeps popping up in one problem area on every IPAD. I have used the adhesive that the new screens come with, i have also tried buying different adhesive and still get the same issue. I make sure the frame is cleaned of any and all old adhesive and i make sure that the frame isn't obstructing the new screen from laying flush. So far i cannot find any answer and i dont understand why im having such a hard time with this issue. Every video i watch never puts much information into this problem and always act as if you just place it down in the right place and it always stays. Any help would be very greatly appreciated. I am finding myself straying away from IPAD repairs because of this issue and if anyone has any answers it would be greatly appreciated. thx
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
Hi david,
This has been answered before. See here and let us know if it helped.
I've found that properly seating the digitizer and digitizer cable will allow the panel to sit flush without any kind of pressure.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Bet if pops up on bottom left..
The screen cable needs to be folded between lcd and not against frame
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
When putting the screen back on an iPad, I've found that the adhesive works better if it's heated up after you place the screen on. The best way to do this is to use the iOpener to provide heat while gently applying pressure to the area of the screen that you are heating
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.の画像
製品
iOpener
$17.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have this problem, too, except it is on my iPhone 5S. I have replaced the screen a couple of times, but the affects haven't been clear until the screen started popping up on the side where the volume buttons are. It also has been shutting down continuously every time I do so little as tap the screen. The phone is old, but I found out that it can be fixed; the battery is just swelling up from overcharging and all I have to do is replace it. I'm not sure if it is the same for iPads but hopefully it may work as well!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 9,537
