メインコンテンツにスキップ
MacBook Proの13インチディスプレイ搭載モデルの修理情報・ガイドです。
9744回答 すべてを表示
4sns/1/c0000008 : taop -- 124
Hello!
Yesterday I've bought Macbook Pro 13 2012 without hard drive. When I installed it at my home, I faced with next trouble: system was too low and fans worked at maximum speed. And my macbook doesn't see battery.
I made AHT and got next information: 4SNS/1/C0000008 : TAOP -- 124.
Do you know what is it?
Update
I made full test in Apple Service Diagnostic and I've got next results:
[12/28/14 13:15:31] Temperature (TA0P) -- Ambient Air Sensor (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[13:15:31] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
[12/28/14 13:15:31] Temperature (TC0P) -- CPU Proximity (test #1) - Sensor Reads Within Operating Range
[12/28/14 13:15:32] Temperature (TM0P) -- Memory Proximity (test #1) - Sensor Reads Within Operating Range
[13:15:32] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
[12/28/14 13:15:32] Temperature (Th1H) -- Fin Stack (test #1) - Sensor Reads Within Operating Range
[13:15:33] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
[12/28/14 13:15:36] Temperature (TA0P) -- Ambient Air Sensor (test #11) - Extended Sensor Flat Line Test
- Checks that the Sensor changes value i.e. not stuck, with longer time allowance for change (5 mins).
[13:15:36] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:15:36] Temperature (TC0P) -- CPU Proximity (test #11) - Extended Sensor Flat Line Test
[13:15:37] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:15:43] Temperature (TM0P) -- Memory Proximity (test #11) - Extended Sensor Flat Line Test
[13:15:44] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:15:44] Temperature (Th1H) -- Fin Stack (test #11) - Extended Sensor Flat Line Test
[13:15:45] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:48:58] Thermal Interface - Processor:Processor0: TIM Test 75 percent GB (test #4) - TIM Test 75 percent GB
- Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guardband.
[13:49:41] ERROR -- 255 [Unknown result-code 0xff] -- TEST FAILED
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
zieevkamol, I believe your error code is referring to ambient temperature sensor (in your case most likely the HDD sensor). Check to make sure that sensor wasn't damaged somehow and/or that you plugged it back it.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hello! Thanks for your answer!
But do you have an image of it? How can I find it?
さんによる
And one more question: I removed HDD, but it doesn't change anything, problem is still existing. Does it mean something?
さんによる
It should be the temperature sensor on your HDD not your HDD itself:-)
さんによる
コメントを追加
TA0P is for
Ambient Temperature Sensor
T = Temperature
A = Ambient Temperature
It is likely that your sensor is dead. OR, if you opened up the computer, you might have connected the connector in the wrong direction. I did not believe that it can be connected wrong way, but it did and I learned the hard way.
And, the names on the the board are not visible when the wire is connected, because it is written below the wire near the connector.
On Mid 2011, 27 inch this two wire connector (Ambient Temperature Sensor) is on the main board on the bottom left side near the fan.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Sorry. My English is not fluent.
I had the same problem: "system was too low and fans worked at maximum speed. And my macbook doesn't see battery".
My problem seems to be liquid damage. I have cleaned the main board with water and alcohol, and I have fixed the problem regarding speed and fan. But the MacBook doesn´t see the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
zieevkamol さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 6
今までの合計 3,222
