4sns/1/c0000008 : taop -- 124
Hello!
Yesterday I've bought Macbook Pro 13 2012 without hard drive. When I installed it at my home, I faced with next trouble: system was too low and fans worked at maximum speed. And my macbook doesn't see battery.
I made AHT and got next information: 4SNS/1/C0000008 : TAOP -- 124.
Do you know what is it?
Update
I made full test in Apple Service Diagnostic and I've got next results:
[12/28/14 13:15:31] Temperature (TA0P) -- Ambient Air Sensor (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[13:15:31] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
[12/28/14 13:15:31] Temperature (TC0P) -- CPU Proximity (test #1) - Sensor Reads Within Operating Range
[12/28/14 13:15:32] Temperature (TM0P) -- Memory Proximity (test #1) - Sensor Reads Within Operating Range
[13:15:32] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
[12/28/14 13:15:32] Temperature (Th1H) -- Fin Stack (test #1) - Sensor Reads Within Operating Range
[13:15:33] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
[12/28/14 13:15:36] Temperature (TA0P) -- Ambient Air Sensor (test #11) - Extended Sensor Flat Line Test
- Checks that the Sensor changes value i.e. not stuck, with longer time allowance for change (5 mins).
[13:15:36] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:15:36] Temperature (TC0P) -- CPU Proximity (test #11) - Extended Sensor Flat Line Test
[13:15:37] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:15:43] Temperature (TM0P) -- Memory Proximity (test #11) - Extended Sensor Flat Line Test
[13:15:44] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:15:44] Temperature (Th1H) -- Fin Stack (test #11) - Extended Sensor Flat Line Test
[13:15:45] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/28/14 13:48:58] Thermal Interface - Processor:Processor0: TIM Test 75 percent GB (test #4) - TIM Test 75 percent GB
- Check that CPU heatsink is properly attached, using product spec theta dh + 75 percent guardband.
[13:49:41] ERROR -- 255 [Unknown result-code 0xff] -- TEST FAILED
この質問は役に立ちましたか?
