メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
What can cause a blank black screen on iPhone 5S?
I am trying to repair an iPhone 5S. I have tested its LCD, and it is working perfectly. I connected the phone to a laptop, and iTunes just responds correctly as if it is a normal iPhone, displaying its information, contents in memory, etc. But there is nothing on the iPhone screen. I wonder if there is anything other than the logic board that can cause zero video output to the LCD.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
1件のコメント
Got an old phone from a friend that does for me ( I'm hardly a tech head
さんによる
コメントを追加
14件の回答
最も参考になった回答
Press and hold down the Sleep/Wake button and the Home button simultaneously for at least 10 seconds. The screen will clear out and then the Apple Logo will appear on the black background. When the logo appears it means that the reset is done.
このアンサーは役に立ちましたか?
スコア 12
6 件のコメント:
well done! thanks!
さんによる
Thanks! It really helps
さんによる
what if your home button doesnt work
さんによる
Thanks Vanilaleean for a concise clear explanation. Fixed a scary problem.
さんによる
3times fastclick home button,backlight will turn on...try it.
さんによる
1以上のコメントを表示
コメントを追加
Do you have the old screen to test the phone with? If so try that and if that displays correctly then it's the screen it self
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
Try to reseat the connector if everything works
さんによる
And do a hard reset.. Holding power button and home button
さんによる
I have four different working screens to test with and none is showing anything. I also tried using a working logic board from another phone, and nothing shows up on the screen either.
さんによる
Just done a full re-assembly and problem solved. still not sure about what went wrong though.
さんによる
My sons iPhone 5s droned totally of power and even after being plugged in all day trying different iPhone chargers! It gives us the apple then goes to a black blank screen like it is on but nothing on the screen! I have tried several times to hold down home button and power button and it does it all over again with same results! Any help appreciated!
さんによる
2件以上のコメントを表示
コメントを追加
This makes no sense at all screens work but not with 5c change logic board and still don't work now they don't?? Confused
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have same problem however, i cannot turn off phone. I can use voice commands but nothing screen related. this after i dropped my phone and ended up with vertical lines turning into eventual purple screen. I tried reseating connectors. now have black screen. Any suggestions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i too have the same problem and I have tried every steps but nothing has worked. please help me out
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Why wont it let you turn it on when the I tunes logo pops up?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
3times fastclick home button...try backlight lite.
さんによる
コメントを追加
Thanks a lot! It really helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
why did my iphone screen got darker as i pressed the power button
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
try reseating the screen connector
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My iPhone 5s is not turning on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My iPhone 5s won't turning on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What makes an iPhone to show black screen? Here are some reasons.
  • An issue with the logic boards and causes black screen.
  • Issues with screen orientation.
  • Physical fault in the device.
  • Caused by some third-party apps.
If it’s not a hardware issue, you can simply fix the black screen problem without data loss with the help of Fixppo.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
1st Solution - Restart Your Phone… 2nd Solution- Setting > general > accessebility > And Turn Over The Voice- over feature…?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can you see any sort of liquid damage on the logic board? A minor liquid can damage the conductors and transmitters.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jjackzhn さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 30
今までの合計 51,592
