メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1234回答 すべてを表示
iPhone 5C Gps not working perfect
Hi guys,
I was wondering,
i just build whole my iphone over in a new frame,
now one thing is not working perfect like it should be,
the gps is not verry precisely , when i enter an adress it keeps changing my position, its like it has an bad connection .
where is the GPS located in my celephone
is it the wifi board,
or is it the small golden bracket on the top side of the phone because it should lay perfect but i still dont understand why it does not work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Tips: Improving phone GPS performance
Turn phone off/on
Turn location services off/on
Perform a GPS reset:
1. Double tap the home button. This will bring up tile sized images of all currently running apps. Swipe the screens of all apps upwards to close them.
2. Then go into settings and turn on airplane mode.
3. When you've done that go to settings, general, reset and choose reset network settings (you will need to re-enter your wifi passwords!)
4. Once your phone has reset go to settings, location services, turn it off then on again.
5. Then go settings > privacy > location services > system services, setting time zone OFF.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
didn't work after following instructions
さんによる
コメントを追加
Check the top logic board screws and contact washers/clips are properly installed (iPhone 5cのリアケースの交換 step 47,48,54-62). Also check the RF bridge cable along the logic board(you can see it on step 53).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
glennjacobs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 8,835
