メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
Why is my screen black after installing a new HD and RAM
I recently followed the steps for installing a new hard drive (the recommended 500gb drive) as well as new RAM (crucial 8gb, 2-4gb). When trying to power up afterwards, I hear my computer turn and it accepted my install disc but the screen remains black. I did unplug the battery during repair but plugged it back in. I did not notice anything break or go wrong while replacing. I appreciate any thoughts.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Double check the seating of the RAM and the HD cable. 99.044% of the time a reassembly issue is a connector (connection) that turned out to be lose or incomplete. Of course the RAM is 1066 MHz DDR3 SDRAM (PC3-8500).
Have you tried to boot from a different volume? If the HD is not formatted, and there's no OS on it you should at least get a grey screen - to install the OS and format the drive you will need a boot volume of some sort.
Connect an external monitor - if that works normally you have an onboard video chain problem (at lest the CPU/GPU logic board are OK)
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the quick response, I'm not going to have time to mess with it again for a few days but I'll give those things a try.
さんによる
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 873
