Logic board fuse blown
Hello i think i must have blown that fuse those two screws is there a way to fix it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Mtaka, that is a Diode. It is a RCLAMP2402B diode and can most likely be replaced. If you have never soldered an SMD device, you could just replace the MagSafe DC in board. runs around $10 to $15USD board
このアンサーは役に立ちましたか?
...and many pins seems to be damaged on the LVDS socket. Could you post a close up pict of this socket and the LVDS cable connector end ?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 448
