メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
Home button feels sunk in and sticks
I replaced the screen on my first iPad Air ever. Before closing it up I did the usual QA check. And after closing it up I did it again. All was well on my bench. Two days later the customer contacts me to tell me that the home button was sunkin and sticking. Sure enough when he brings it back to me, it's sunk. I removed the screen and compared it to the old one (which thankfully I had not tossed yet) and there was a missing cushion. I replaced the cushion and sealed it again. I test it and it works fine. Call the guy to come get it and show it to him while he is there.
He calls me an hour or so later and says it still has the same problem. So I offer to replace the screen at no cost to hime. I order from a different company and make sure that I odrdered the screen with home button installed!!!!
I put the new screen in and transfer the cushion. Sure enough after a day of usage, the fellow calls me AGAIN and says the same thing is happening.
I know this person, not that well, but we travel in the same circles so I know he's not putting one over on me or anything like that. The problem is legit.
Anyone else have such a problem with an iPad Air? What did you do to resolve it?
Thanks,
Norm
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
3件の回答
最も参考になった回答
There are few things that could have gone wrong.
Check out this post, it's quite similar to your problem and has some very good solutions.
replaced glass, home button sunkin in?
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Put your lips on the button and suck really really hard. It'll pop right out. Worked for me.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It works and then when I press it again it gets stuck again
さんによる
At times, Apple sux 2.
さんによる
コメントを追加
Hold the power button until "slide to power off" shows up. After that release the power button and old until it turns back into the home screen. If it turns on Siri, it's ok. This just helps to clean the ram :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Norm さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 53
今までの合計 64,864
