メインコンテンツにスキップ
2011年7月21日に発売されたMac Mini Mid 2011モデルはCore i5もしくはCore i7プロセッサ、Thunderboltを搭載しています。
204回答 すべてを表示
How to remove logic board?
In the teardown it just show someone putting two screwdrivers into the blind holes and the comment that this saves the Apple-special-tool ("logic board removal tool", probably just a joke).
When I insert a screwdriver or whatever into these blind holes, I can touch the ground of the case on the other side, but I don't feel they can move anything.
How should this work exactly?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Here's the tool they are talking about:
Mac mini Logic Board Removal Tool
Mac mini Logic Board Removal Toolの画像
製品
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
that is used as a way to push the logic board out the back. all you do is
1. make sure the back of the mac mini if facing you.
2. make 100% sure that you have got all the screws ( the tear down missed some screws).
3. make 100% sure that you have disconnected everything (i broke the clip to my IR sensor by not paying attention)
4. put two screw drivers in the holes and pull towards you
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
So the holes are actually not needed? I could just move the logic board somewhere else also? This didn't work for me.
さんによる
yea thats what i did.
さんによる
@robwariii
Could you please post a picture of what screws that should be removed?
Would appreciate it!
/ Viktor
さんによる
コメントを追加
I successfully used a small 2mm Allen key to detach the logic board. You shouldn't use anything tightly fitting, since, from what I understand, it's a levering action: fixed point is at the bottom of the case while the two holes in the logic board move to the back (connectors side). You can even get away with a single key/screw driver, if you alternate carefully.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
How do u know what screws were missed?
さんによる
@Lou Capozzoli - The issue is not screws! The logic board is like a stuck drawer in a desk.
The Allen key is used to gain leverage to hold the logic board so you can ease it out. I prefer the proper tool Mac mini Logic Board Removal Tool that way its safer from slipping which could damage your logic board.
Review this guide Mac mini Late 2012 ロジックボードの交換 jump down to Step 15 which shows what's needed using the tool. The guide will weals you through the needed screws and other connections which need to be dealt with before sliding out the logic board.
さんによる
コメントを追加
回答を追加する
http さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 54
今までの合計 18,029
