メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
Can you replace the i5 processor with an i7?
I would like to upgrade my i5 iMac with the 2.93 GHz i7 processor.
Is that possible and has anyone already done it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
1件のコメント
I would like to do the same!
さんによる
コメントを追加
13件の回答
ベストアンサー
That answer is incorrect. The processor is socketed, so the upgrade is possible physically. I've not heard of anyone successfully doing it though. Wouldn't it be nice if iFixit tried for us? :)
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
it could work, there are socket LGA1156 i7's and maybe LGA1156 i9's (6-Core 32nm, "Gulftown" CPUs comming in 2010)
さんによる
Wow! Great! Wonderfully done!
さんによる
Thank you. It was frustrating to read all of the incorrect answers in this thread, stating that the 2010 27" iMac processor could not be upgraded. Good luck with your upgrades.
さんによる
コメントを追加
The i7 Intel processor in the 27" iMac is a 2.8 GHz Intel Quad Core i7-860
Uses the LGA1156 Socket
But its the only one in the group that has expanded options available on chip.
'''Expansion Options
PCI Express Revision 2.0
PCI Express Configurations 1x16, 2x8
  1. of PCI Express Ports 1
''' This is the spec sheet from Intel for the Quad Core i7-860 :
http://ark.intel.com/Product.aspx?id=413...
This site is the Intel's i7 Family Product spec sheet:
http://ark.intel.com/ProductCollection.a...
In conclusion It may be possable to to replace a i5 with the i7-860. but you may not be able to replace a i7-860 with a 3.20 GHz Intel Core™ i7-960 Processor
Kristyanna Virgona
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
@ Krisyinfo
no, a i7 960 is not possble, it is a Bloomfield, a processor with a completely different socket.
Funny someone gave you one score, you know nothing, bud
さんによる
@John
I know the i7 -960 will not work if you read the last two lines of the post it read's as quoted.
"In conclusion It may be possable to to replace a i5 with the i7-860. but you may not be able to replace a i7-860 with a 3.20 GHz Intel Core™ i7-960 Processor"italic text''''
I have two 27" iMacs one with the i5 and one with the i7. We open both up to put a larger HD in them and looked both CPU's are socketed and the i7 860 is the only one you can use until Apple use up the motherboards so that it will use a faster i7.
'''My runs Call of Duty 4: Modern Warfare, really fast no dropped frames, smooth action.
Kristyanna
さんによる
コメントを追加
I can see everyone is talking but no one actually spent 1000£ just to try it, well I did and the answer is No. In my case I tryed to upgrade the 3.06 i3 processor mid 2010 iMac with the i7 860. The processor fits all right and the iMac starts but it does not boot, wich means somehow the bios does not recognise the processor. Could be a power issue wich I'm not 100% sure because it starts. But also could be the nm issue. The i3 is 32 nm the i7 is 45nm. It deffinetly works with a processor that has the same socket , nm, and power as the existent one wich means an i5 but that's not too much of an upgrade is it?
C0L3 ST. J0HN
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Yep it works from i5 760 to i7 870. Always chech the specs of booth processor they should have the same nm and power and socket.
C0L3 ST. J0HN
さんによる
コメントを追加
as long as these are socketed i wouldnt see why not, ebay has the 1156 intel core i7's in both 2.8 and 2.93 GHZ and they are both 95w which seems to be the same as the core i5
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I dont think you can upgrade the Processor to the one you are talking about, beacause of the Socket, the Core i7's Used in these are Socket 1156, if the Processor your talking about is a i7-940 then thats socket 1366 so its not compatible, and dont forget about heat concerns.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The i5 has 1156 BGA. The two entry level i7 (i7-850 & i7-860) also has 1156 BGA. My iMAC has the 1156 socket.
Note: The iFixit teardown pics are of a Core 2 Duo system.
Jim
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Since the iMac is alo offerd with an 1156 form i7 2.8 GHz chip as an optional upgrade, I'd wager that at the very least THAT particular chip would work. The 2.93 part may work to, but the BIOS must support the part and that is up in the air. I'd say the chance of success for the 2.8 i7 chip is probably high enough to warrant a try though.
It'd be great to find future support for additional 1156 based chips inside too!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yes, it works 100%! I don't have a link, but I have read it somewhere on the internet.
There is though not a single reason to void the warranty to upgrade the CPU.
i7 860 is not that better than a i5 750. HT is still not used by 99% of the programs. It just will eat more power, that's it.
In two years, when your warranty is up, you can try that. And yes, it will work!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
yes , it will work, is the same socket and apple supports those processors, i change a while ago to my old iMac 2.0 to 2.8 extreme , works like a charm, what i need to know is if the new iMac [2010] 3.06Ghz socket lga 775 can be upgradable with a Quad core same socket ? [ cuz apple have not suppoted YET that processor in 10.6.3 ]
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
as I know that iMac27 design with i5 1156pin socket CPU, if it's possible without any BIOS update to change into i7 1156pin CPU? on the other hand, If I change CPU by myself after warranty, can I get BIOS or F/W solution from Apple's technical support? if any charge I accept.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello jedmunds1,
Yes, there is a high possibility that a i7-860 and i7-870 CPU will work because these processors, included the i5-750 are based on the same core, named "Lynnfield" and are all the same.
So if you are trying this at home be careful and good luck!
J.T.
P.S. Don't use the unlocked version of the i7-875K, BIOS not supported.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i did an upgrade on my imac 27" that was originally i5 750 to a i7 950. Its working fine, never had any crash, since 2012. it works hotter than the i5, but i use smc fan control for more cooling.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can I replace an Intel Core i5-2400 CPU 3.10GHz with an i7? If so which one? It's a Dell
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jedmunds1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 58
今までの合計 103,456
