メインコンテンツにスキップ
様々なテレビブランドとスタイルの修理ガイドならびにサポート
9064回答 すべてを表示
Sony Bravia 40" LED TV Screen cracked, looking for replacement screen
My Sony Bravia 40" LED TV KDL-40R350B screen is cracked. I'm looking for a place where I can find a replacement screen, can anyone help me? Model KDL-40R350B. Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント
R562c screen replacement how's cost
さんによる
I have a Sony Bravia Smart TV and it is model number KDL 40 r510c and I need to know the cost of that panel
さんによる
Why should a tv cracked. mine doesn't felt from distance. and its not even 2 years old. My old tv felt from 4 foot distance nothing happened . New one is not good. $499.00 cost.
さんによる
If a TV cracks . what part do we need to change
さんによる
@Julia - What is the part that is damaged? In this case the display screen was damaged (cracked). You should create own question with your TV's details.
さんによる
コメントを追加
2件の回答
ベストアンサー
Boy I hate to tell you this getting a new TV will be cheaper!
When the TV's were going for around 2k one could get a replacement screen. While its a lot of work to replace it was possible! And Sony did set things up so it was not that hard to do.
Sadly, the cost of this model is around $300 used and a 40" new is not much more for a similar TV.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
i have a intact screen from an sony bravi with the model #lty260w2l0300r7. the sccreeen is labeled samsung though . the tv broke but i recovered the screen part intact email me obdemirelli@gmail.com if this will help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jermaine さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 20,522
