メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1169回答 すべてを表示
How do I clean the LCD panel before reinstallation and reassembly?
I just replaced the glass on my 3G and am wondering what products I can use to clean the lcd panel itself before I reassemble as I am betting it is very important this is perfectly clean.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
You are right, it is important to make sure the LCD is clean. Anything that is stuck to it will be clearly visible when you reassemble. Use a microfiber cloth to clean off the LCD, canned air is useful too. You can find both of these at most hardware stores. It is also important to work in a clean, dust-free environment.
Make sure you do all that and you should be fine.
Good luck!
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
+ Ralph
さんによる
So, I just tried the microfiber cloth (used brand new one) and it got rid of any dust but there was one fingerprint on it that just seems to have been smeared around :(. Any idea if I can use any sort of cleaning solution (alcohol based?) or will it wreck my screen?
さんによる
Is this on the LCD panel or the front glass?
さんによる
I have good luck with a qtip and rubbing alcohol over 90%
さんによる
コメントを追加
you can replace the spring with a flintstone spring of a disposable lighter - of course only a short part of the spring. cut the spring to the lenght you need and solder it to the logic board. maybe you should stretch the spring a little bit before you cut it, that way it will be a little bit more flexible.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
+ Andrew
さんによる
コメントを追加
The actual LCD panel not the front glass :( unfortunately.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I would avoid cleaning solution, just try again with the cloth
さんによる
コメントを追加
I used yet another clean cloth and that seemed to get rid of everything. Re-assembled the phone and the touch screen works and looks great! But now my home button doesn't work :(. After re-disassembling I found one of the tiny sensitive little spring contacts for the button had broken off inside the phone. I think the only way to fix it is to solder a pin about 1/16th inch long onto the contact to get it to press against the other contact point on the phone. Otherwise I could tear off the digitizer and glass I just replaced and replace the whole home button assembly...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex Williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 19,429
