メインコンテンツにスキップ
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
screen black but touch works..
I have changed the screen on my LG G2 and it went well. Now when I start it the touch works but the screen is completely black (I hear that I can unlock the lock screen) What should I do about this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
After replacing the screen on the LG G2 you need to do a soft reset. Hold the power button and the down volume button simultaneously to do this. The screen should work now. If not, it's likely an issue with the connections inside, or maybe you pinched/ripped one of the cables on the new screen.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Your answers are very good. Please complete your profile so we can get to know you better ;-)
さんによる
コメントを追加
Check if the LCD connector get loosen and replug it. At the same time, check if the flex cable or connector is broken.
And the most serious result after trying above is your phone is broken again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jonas Lindberg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 382
