Why won't my device charge?
I own a HTC Freestyle and when I plug in the charger, the device does not indicate that it is charging.
If the device will not charge and does not indicate that it is plugged in, the problem is most likely that the charging port on the phone is faulty or damaged. To fix this you will need to replace the charging port. For troubleshooting click here.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 266
