Is it acceptable to use large pots or pans?
I am unsure if it would be safe to use pots and pans larger than the heated surface area.
I've done so on a conventional home oven, but I am worried if this hot plate can even handle the bigger loads.
It won't hurt anything, but it could be not safe as the possibility of the pan/pot spilling over.
The other factor is the transfer of heat will give you a hot area unless your pan/pot is clad with a Copper or Aluminum core to smooth out the hot spot.
You will also need to think about the volume you are heating here. Boiling a large pot of water will take longer and it may not be able to sustain (recover) the boil. Review the BTU's of the heat plate.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 10
過去 30 日: 13
今までの合計 133
