メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
Is there a better way to reattach the Display cable?
I recently upgraded my HDD, and when I went to put my display cable back into it's port on the board, it has a blank screen and occasionally a fan runs fast. The LED troubleshooting lights only have 3 out of the 4 lit up, indicating a problem with the LCD display. I get a chime upon boot, but the fans and the HDD remain active. I checked out the Logic board and it does not have any damage. I can only assume that it is the cable itself since the pins on the MLB side somehow get slightly bent whenever I try to insert to the board.
I am not sure what I am doing wrong, because obviously I am doing something wrong when I insert the cable in the port and the pins get bent. Is there a better way to reattach the cable to the port without damaging the pins on the cable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント
Did you ever find an answer to this question? I have the same problem.
さんによる
I found out it was better to attach the LVDS cable carefully to the logic board - and then to the top of the LCD. No way I can with my big hands can insert it again correctly from an angle.
さんによる
where do you get a replacement cable, hey?
さんによる
No the cable is in a socket. You need to remove the black tape.
さんによる
Where can a replacement cable be sourced from? Apple doesn't appear to sell just the cable. Who sells just the cable?
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
I had to get someone in with much smaller hands to do this. The cable length is to short for a full grown man. This thing must be assembled by 4' 10" small Chinese women.
UPDATE
Really, I got a tech with much smaller hands and I held the display while they inserted the cable.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Did you hire her ;-}
さんによる
yes. 16 years ago but she only works occasionally now.
さんによる
Was this really accepted as an answer??
さんによる
Well it didn’t help me… but it did make me chuckle as I have the same stumpy fingers and lack of patience…
さんによる
コメントを追加
回答を追加する
Joan Arnold さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 947
