メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Will I lose the warranty?
Hello !
I would like to know if I will loose my warranty when I change the ssd on this macbook Pro.
I can see we have to remove the seal in order to take the battery connector off the motherboard... But is this step really necessary ?
Thanks a lot for your answer and for the amazing job you're doing.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
First, right now Apple is the only supplier of the custom SSD unit used in your system.
Right now I don't know of any 3rd party options so opening your system is moot.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
I was thinking about changing my ssd for a Transcend JetDrive actually.
さんによる
So you reviewed their web site info Transcend. Did you note they don't offer a SSD unit for your model yet (Early 2013 being the newest model they offer a SSD option).
さんによる
That's correct. I just checked out their website and they don't offer a SSD unit for any of the 2014 models yet. I'm purchasing a MacBook Pro 13" soon and it would have saved quite some money if the upgrade was available for the newer models. 256GB of storage is what its going to be for now. . .
さんによる
Oh yes sorry, I forgot about this model thing. Thank you for your answers !
さんによる
But as the 2013 and the 2014 MacBook Pro are very similar in the inside, maybe the JetDrive would work in a 2014 model too !
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Maxime Fitch さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 381
