Why wont my camera switch to the front one?
When i try to switch cameras, the screen just freezes on the image that was shown before the swap. I realy dont know how to fix it so please help.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First, I recommend resetting your iPod Touch.
If that doesn’t help, I recommend restoring your iPod to factory settings using iTunes. Please make sure you have a backup before restoring your device.
If restoring your iPod Touch does not help, it may be indicative of a hardware problem. If you narrow it down to being a hardware issue, hopefully it is only a loose camera cable. Use this guide to get to the front facing camera. If checking the connection doesn’t resolve the issue, you may need to replace the Front Facing Camera.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 645
