メインコンテンツにスキップ
A 3G smartphone also known as the Samsung i9000 Galaxy S, or the Samsung I9008 Galaxy S in the Chinese market, released Spring 2010.
44回答 すべてを表示
The device is not turning on after screen cracked and broken
Some years ago i have dropped my phone (Galaxy S i9000) to the ground and obviously the glass was cracked.
The problem is that the phone is not turning on!
I have changed the entire display Super AMOLED but the phone not turn on!
It's died and when i use the mainboard externally with the charger (without is not do anything) i feels that is very very hot but the soft touch keys is turning on... no display, no sound and nothing, only overheating a lot...
Any suggestion? :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント:
Where does the logic board overheat? Trying a new battery will help with further troubleshooting.
さんによる
Ok, i have ordered a new original battery (but i'm sure that the battery it's OK) and i will try with this! thanks for the moment
さんによる
I am not saying it is not okay, but its a guess. The best way of figuring out what is going on with your phone, is to have a good starting point. A new battery will provide this.
さんによる
I have tested a new battery and the problem is the same, the phone warms and the light of soft touch is flickering and random power on:
http://imageshack.com/a/img661/5880/elXt...
I think than is the ARM Process that warm and be very hot, but only if i press the power on button or i plug in usb power....
さんによる
コメントを追加
1 件の回答
tried a working battery?
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
it's not the battery! the battery not have problems because is outputting the correct voltage and if is the battery, can this cause motherboard overheating? :(
さんによる
in rare cases it can by either putting out too much or too low, okay so how you tried seeing what part of the board gets hot then see what that chip is and its function?
さんによる
it's really difficult to understand what warms because hotness expands on all board :( i will check more accuratly this evening, thanks!
i would do this repair because i want recover all my data from flash! :(
さんによる
さんによる
I discovered than what warms i thinks is the IC MAX8998... :( How may be broken and how fix it or replace?
Thanks.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Emulator さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 3,063
