メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
20回答 すべてを表示
System is very slow after changing battery
My battery life was getting shorter so I ordered a new battery and replaced it with no issues at all. Put everything back together, plugged it back in and the iOS Yosemite took a very long time to boot up. Then after booting up the top menus didn't display for several minutes. The mouse is lagging horribly and programs take forever to load. I have tried rebooting it a few times and no change. I am not sure what could be the cause of this.....any ideas?
Lastly I saw an explanation on how to reset the smc which I did, not sure whether it worked or not but no change in the slowness.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
Decided to put the original battery back in and no more lagging, boots up faster and no issues when fully booted up.....very strange.
さんによる
コメントを追加
9件の回答
ベストアンサー
all MacBook Airs from 2010 onwards need the EXACT matched partnumber for the batteries.
make sure you get the battery labeled as A1405.
do NOT get the battery labeled as A1377 or anything that they say works with any other MacBook Air than the mid 2011 model. (some websites list the same batteries for the 2010 and 2011 models: this is not correct and they're incompatible).
I have had these issues multiple times, had a freakin headache because suppliers kept sending me mismatched parts; always the same result: the MacBook Air freezes up and is using huge amounts of cpu on kernel task because of the mismatched battery.
If you DID order the A1405, then you've probably got a DOA, and you need to send it back in for a swap.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Is there anyway to fix it without buying new battery?
my current battery is completely dead.
さんによる
Im having a similar issue with a 2015 15" MBP and an a1618 iFixit replacement battery since the original battery had been removed by the owner, kernel_task is however not using up a lot of CPU and Intels PROCHOT signal (overheating) is also not being triggered since ThrottleStop doesnt help either in getting more than 0.8GHZ out of my CPU. Is it possible that non OEM batteries without a serial number cause this error? I cannot find any other factor that could be keeping my CPU clock at that rate constantly and already tried two different batteries. Battery health shows as "good" in system information but im getting a PPT004 error when using the hardware diagnosis
さんによる
コメントを追加
I had the same problem, I changed the battery, and my macbook became very slow.
I solved the problem by updating the SMC of my macbook
https://support.apple.com/kb/dl1627?loca...
This update relates to macbooks not recognizing the battery type
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
hey bro, can i know the model and the emc of your macbook air ?
さんによる
コメントを追加
Yeah the battery from the manufacturer you ordered it form problem did something to the battery to make your machine slower. I ran into a few repairs lately that had a battery issue. Didn't know what it was until I saw that the new battery wasn't working properly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
$@$* battery. All Macbooks clock down a little bit without the battery. The Airs are much more drastic here, they are %#*@ near unusable without the battery. The first five to ten percent works like junk, after that it should be good.
If it still works like crap at 100%, try getting a REAL battery and yes expect to pay over seventy bucks for something of worthwhile quality.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Often a slow computer is caused by a HD that is too full. In order for the OS to create/write VMEM and swap (temporary) files you boot volume must have 10% of it's total volume free (empty) for this purpose.
You can find out if your boot volume is too full, (if it's really full you get a error message at boot) and delete inconsequential data to create enough free space.
Another reason for a slow computers is a boot volume with permission or MBD problems. Booting to repair (R) and running Disk Tools->Repair permissions and Repair Disk can cure those issues.
Lastly if you did not opt out of full disk encryption at install of Yosemite that slowdown is the files being encrypted... it should be significantly faster over time if that was the cause.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
thanks machead3, I have 53 gig of available space left. The only time I ever experienced the laggy/slowness is right after the battery was replaced. I tried various things to correct that but in the end with any troubleshooting is looking at the last thing that was changed/modified. Put the original battery back in and now the macbook air is running just as it did the first day i bought it. I decided to send that battery back and order one from a different manufacturer. I will see what happens when I get that battery and install it.
さんによる
Good move - when in doubt contact the vendor.
さんによる
コメントを追加
I had the same problem. You must have a defective battery. Unplug the battery and run without it. Your computer should run much much faster. This was driving me nuts till I discovered it just tonight.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
how do i unplug the battery? isn't it inside of the computer?
さんによる
Take a guess.
さんによる
Unplugging the battery is not an option anymore since you need a custom OS X kernel patch to disable the CPU PROCHOT signal that the machine produces when not detecting a battery, keeping the processor virtually throttled
さんによる
コメントを追加
The fix is to reset the SMC as follows:
  • Turn off the mac
  • plug it in
  • hold ctrl-alt-shift-power for a few seconds
https://dntruong.wordpress.com/2017/11/1...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have Macbook Air A1370 (MacbookAir4.1, High Sierra)
I had to replace an original nearly dead battery with the replacement I bought on eBay.
I received A1495 battery instead of A1406 supposed for my Mac (even it was advertised as compatible)
When I replaced the battery the system became extremely slow, but as it was in another country it was very hard and costly to return/exchange battery.
Finally I found a solution.
You have to delete one plist file from your system.
You may find the solution here:
http://machmachines.com/macbook-pro-runn...
To be able to delete a plist you may have to disable SIP:
https://www.macbartender.com/system-item...
Saved me a lot of time and money :-)
P.S. I also tried to update SMC, but I didn't find a solution for High Sierra as an update mentioned earlier doesn't work on High Sierra and I'm not sure the SMC on my Mac is up to date.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
google => macbook-pro-running-slow-battery-fix
To be able to delete a plist you may have to disable SIP.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
petersonkevin さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 79
今までの合計 44,247
