メインコンテンツにスキップ
本製品は、2010年7月27日にAppleから発売された解像度2650x1440ピクセルの27インチLEDディスプレイです。モデルナンバーはA1316。
78回答 すべてを表示
Blank screen and odd behavior of MacBook and iMac
Hi there,
when I connect my display, it is recognized by iMac (2012) and Macbook Air, it shows up as LED Cinema Display, speakers, mic, iSight camera, USB ports are working and I can move the mouse cursor where the display should be.
But the screen is black. No dim light, no faint image under a flash light, it is pure black. Additionally the iMac seems to have micro freezes or at least the mouse moves very slow and stutters when I connect the display. The MacBook Air's internal display shows artifacts and it also seems to freeze and the mouse doesn't react well. As soon as I unplug the display, everything goes back to normal.
Can only the LCD be the faulty part here? How can I find out what needs to be replaced? I've read about voltage checks on power supply and logic board and test points, but where do I find a 'map' of these boards to identify these test points?
lg, Alexander
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Could be the this problem.
Can you get Apple to diagnose/estimate what's wrong? These are very complicated units.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
elvock さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 413
