メインコンテンツにスキップ
Apple Studio Display M7649 Logic Board Replacement
必要な工具と部品
  1. Apple Studio Display M7649 Logic Board Replacement, Stand: 手順 1、 2の画像 1 Apple Studio Display M7649 Logic Board Replacement, Stand: 手順 1、 2の画像 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Logic Board Replacement, Panels: 手順 2、 1の画像 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Logic Board Replacement: 手順 3、 1の画像 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Logic Board Replacement: 手順 4、 1の画像 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 Logic Board Replacement, Metal EMI Shield: 手順 5、 1の画像 1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 Logic Board Replacement: 手順 6、 1の画像 1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 Logic Board Replacement: 手順 7、 2の画像 1 Apple Studio Display M7649 Logic Board Replacement: 手順 7、 2の画像 2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 Logic Board Replacement, Logic Board: 手順 8、 1の画像 1
    • Remove the four screws holding the logic board to the display
  9. Apple Studio Display M7649 Logic Board Replacement: 手順 9、 1の画像 1
    • Remove these seven cables connected to the logic board.
    • There is an extra connection that no cable plugs into. This connection is for Apple to test their logic boards
  10. Apple Studio Display M7649 Logic Board Replacement: 手順 10、 1の画像 1
    • Remove and replace the logic board.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Tsao
メンバー登録日: 01/19/10
186 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G20
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 4,942
