The lights are not turning on but the engine is running.
When I start the motorbike, the engine starts up just fine, but the head lights do not turn on no matter what I do. How can I fix this?
If the head lights are not turning on even though the motor is running, the bulbs may be burned out. Make sure they are screwed in all the way and check the connection wires to the lights. If this does not solve the problem, they will most likely need to be replaced. Please refer to the troubleshooting guide for more information.
このアンサーは役に立ちましたか?
Check bulb and fuses. Then check if power is getting to the bulb with a volt meter.
Mine has new bulbs and fuses along with power to the bulb, but still isn't coming on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 355
1件のコメント
Lights are not working
Street Smarts さんによる
