メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
Bluetooth 4.0 upgrade parts
After upgrading to Yosemite, I have seen that there is a Handoff Breakdown With Activation Tool
http://forums.macrumors.com/showpost.php...
for older macs.
As Handoff needs bluetooth 4.0 to work, there are instructions on the post about if and which cards are needed to upgrade non bluetooth 4.0 macs... Apart from my mid 2010 macbook.
Does anyone know if its possible and which bluetooth/wifi card i need to upgrade my bluetooth so I can use Handoff??
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Been looking for more info on this but can't find anything. Have you got any links? Cheers. Just want to know it is completely compatible.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
So far only the MacBook Pro systems have been upgradable
さんによる
Follow the links at right. You'll see there's a sorta kinda upgrade success for some "unsupported: platforms however these are not simple plug and play solutions they involve both hardware changes and hacking the OS.
さんによる
コメントを追加
I use an ASUS USB Bluetooth Device with the Continuity SW and Still Works With the Latest High Sierra Update!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
neil whitten さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 19
今までの合計 1,097
