メインコンテンツにスキップ
Released in 2008, part of the Air Warrior line of Buzz Bee foam dart guns. Features include a large ammo capacity and an automatic firing mode. Repair in most cases is easy, requiring only simple tools.
5回答 すべてを表示
How do I stop darts from getting stuck and jamming the gun?
I've noticed that when I fire and use my dart gun for extended periods of time darts have a tendency to get stuck near the tip of the gun rather than firing out normally. Is this due to a defect in how the gun was built or some other issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I have a Nerf Ultra Speed and for some reason the bullets are not coming out of the mag and making it jamming and shooting slowly, why is that?
さんによる
コメントを追加
4件の回答
最も参考になった回答
If your darts get stuck, it might be your gun or the darts themselves. Sometimes after being fired many times and successfully hitting many targets, the darts will get bent or weakened, this will jam the gun and they might get stuck. Check out the Troubleshooting Page for more help!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
It is actually due to not pulling the trigger hard enough. When you pull the trigger it pushes the bullet into the powered barrel so if you half pulpit it gets jammed between the ammo clip and the barrel!
さんによる
You might have to use a special thingamajig. Moira is right.
The darts might be chewed up or damaged from another gun.
さんによる
コメントを追加
I think that anonymous is wrong because that if you only pull the trigger hard, it only shoots. It has nothing to do with gun jams. Check the bullets and the gun, Garmsen.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
if you see a very small button on the side of your nerf gun, press it and $!^& the gun and it should unstuck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
my nerf gun was stuck bc it is a xshot zuru gun with balls and then i tryed what soyboy told us and it works thx soyboy
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
my gun did the same thing
さんによる
コメントを追加
回答を追加する
Reed Garmsen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 58
今までの合計 15,494
