Wifi on my Samsung s duos is not working
When I on the Wifi, it goes into light green mode and does not come into complete green mode[Which is wifi adapter is failing]
Any suggestions on this.
Tried factory re-set but still the same.
Dear All,
Wi-Fi Freezing fault may occur due to 10% of Wi-Fi driver related issue and 90% of WiFi hardware fault,
Simply you can use hot air flow to U204 module and check whether it's functioning back to normal
other wise you will have to repalce new U204 Wi-FI + BT module
Here you can find parts for repair
Note : BGA reworking skills required to replace WiFi module
Hope you will be able to fix the fault your self.
Cheers!
このアンサーは役に立ちましたか?
このアンサーは役に立ちましたか?
dail*#*#526#*#* on your phone keypad this will show a message driver software sucessfully installed than try to turn on wifi this will turn no easily
このアンサーは役に立ちましたか?
It's not working.. can u please suggest me any other solution. .
it's not working ...... can u plz give another way to solve this problem ...
It is not working and can you please any other way to solve this problem
when we on the wifi the siginal ra not displayed on the screen what we should do for that
このアンサーは役に立ちましたか?
is it your own WiFi signal if it is, is it been set with a password for protection preventing other users connection to your signal?
Usually if it's able to pick up the wi-fi network but does not want's to connect is usually with the secuirity settings. you can try by deleating that as you defalt network and the se-activate it (try to reconnect to it) the default proiblem is usually the security settings.
このアンサーは役に立ちましたか?
the same problem occurs on not protected wifi..
all site are open with wifi but not download any app my phone with wifi
このアンサーは役に立ちましたか?
Try. *#0011# > Menu key > Select Wifi > Select Power save button Off
Thanks
このアンサーは役に立ちましたか?
Tried this but not working
samsung s duos wifi not turning on
このアンサーは役に立ちましたか?
you should heating wifi and bluetooth ic and reboiling it or change it
このアンサーは役に立ちましたか?
My s duos i droped it in water then i put it in rice for a few days then i turn it back on everything worked except wifi and it was on low green. Before the water incident it was perfectly fine
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 77,799
6 件のコメント
i hav the same problm,,wt can i do nw,i tried so many times its nt workinngggg
sr534223 さんによる
mi wifi no funciona se daño solo me funciona con paquetes de datos
y eso no megusta por que es demasiado lento
leonardo さんによる
My WiFi connection is on but connecting any network does not connect and shows saved &secured
Ravi Kiran さんによる
My wifi Didn't even turned on.
Super Star さんによる
mobile does not support jiofi hotspot after connecting it show saved and secured but nothing work on it. plz help me why this is happening
Harshit Mahagaye さんによる
1以上のコメントを表示
