メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
Can I replace iMac's harddrive with an SSD?
hi everyone!
I'm using an Intel based iMac (Mid-2011 model) 21.5 inch. It comes with a 500GB hard drive (ST3500418AS) and I'd like to replace (not add a new drive by removing the optical disk drive) that drive with an SSD (Samsung 840 EVO-Series 1TB 2.5-Inch SATA III Model #MZ-7TE1T0BW)
SSD link below:
http://amzn.to/1Ea56Ok
the ssd itself is 2.5 inch and I'm going to convert that drive to 3.5 inch drive by using a WD icepack which is sold on amazon.com for about $20 usd
WD Icepack link below:
http://amzn.to/1rITB9O
first I'm going to attach the ssd into the WD icepack and then I'm planning to replace the original HDD that comes with the iMac by installing the SSD.
My questions are:
1. does apple allow 3rd party SSD's for iMac?
2. do I need any additional cable kit?
3. is it enough to change just the drives? (I mean HDD comes with a termal sensor, does the SSD need a termal sensor?)
4. do I need any software after installing the SSD (if possible) to control iMac's fan speed [I heard some people complaining about their fan speeds and the loudness of the fans]
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 12
コメントを追加
16件の回答
ベストアンサー
First you have a spare SATA port in this model so you don't need to remove your current HD or the optical drive.
So you can follow this IFIXIT guide: Installing iMac Intel 21.5" EMC 2428 Dual Hard Drive Kit. Go to Step 46 as you can see you are wedging the second drive (HD or SSD) behind the optical drive. Once you've put the SSD in you can then create a Fusion drive across both your HD and SSD gaining the benefits of each.
If you decide to just replace your HD for a SSD thats fine to. But you'll need to use this special cable: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade.
Frankly, I think the best option here is swapping out your HD for a SSHD (hybrid HD). Here you'll gain the performance of the SSD but the storage capacity of a HD.
Here's the Seagate web site: Seagate Desktop SSHD and here is the spec sheet for the SSHD series: Desktop SSHD specsheet.
このアンサーは役に立ちましたか?
スコア 15
23 件のコメント:
Thanks for the suggestions Dan. Actually I've ordered the stuff (links available) that I'm going to use for the upgrade on my first message. Do I still need that Thermal Sensor Cable for replacing the original HDD. Because I do not want to use the spinning drive anymore and I don't want to place my SSD under the optical drive (that way it will take about 10 hours for me to disassemble all the parts lol)
May I remove the old HDD and replace my new SSD into its place? I mean, will it work that simple?
さんによる
Yes, You can swap out the HD for the SSD. But you'll need the special cable and a standard 2.5" to 3.5" drive adapter frame (you don't need the IcePack frame as the SSD does not get hot like the WD drive the frame was designed for). A standard adapter frame is about $5.00. Why do you want to go with a straight SSD? The SSHD are very close to the same speed and cost much less for the storage space (the difference is about $300 in your case). If I were you I would return both parts to save the money.
さんによる
I just installed the Seagate SSHD and the fans of my imac are blowing maximum speed. I thought this particular drive is compatible with the thermal sensor interface and so you won't need the OWC thermal sensor?
Did I misunderstand something here?
さんによる
Did you get a drive with an Apple logo on it? The older drives don't have the needed firmware. I would also install this app to see the thermal sensors as it could be a different problem here Temperature Gauge Pro.
さんによる
The drive is brand new. It has no apple logo on it. The guys from OWC said if it's not an apple certified drive you would need the sensor cable. I will try the app. Thanks. Is it OK to operate the imac until I have the thermal cable installed?
さんによる
18件以上のコメントを表示
コメントを追加
Given that this thread dates from the 2014/2017 timeframe, I think the SSHD recommendation no longer applies.
I put in a Seagate SSHD back then and have been thoroughly unimpressed with its performance from day one. Prices of SSDs have plummeted since then which makes SSHDs no longer viable.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Hey @batman113
I've a Mid-2011 27" iMac with a busted HDD.
Just wondering, other than the new 2.5” Samsung 860 EVO SATA SSD that I’ve ordered, are there any other parts that I need to order? I’m a noob and this 3.5” to 2.5” conversion is confusing me. Would I have to buy a converter or would the existing HDD SATA cable do the trick?
I don’t intend to buy the thermal sensor, I’d just manage with smcFanControl.
Appreciate any advice.
Thanks.
さんによる
コメントを追加
Hi, i have same issue, Beware iMac 27 mid 2011, don't work with samsung 860 EVO (Because samsung use unsupported new controller) also same situation can be with 850 EVO (i didn't check with this series), so optimal for upgrade without any risk will be use 840 EVO series. Symptomatic is next: When you connect 860 EVO (I check it) or 850 EVO (I didn't check it 850 EVO, so info for 850 EVO maybe not correct). You can start from internet recovery but you cannot do fusion drive, for fusion drive you should start from USB recovery, yes you can do fusion drive with 860 EVO or 850 EVO but then when will be recovery from time machine you will se error and time machine is stop, then if you will try install new system to you new fusion formatted disk, you will cannot install, not sierra, not sierra high, maybe el captain will work but you will see many error when install it (6 hours maybe), if you still install some OS don't start to be happy, because will be many errors and white screen. So by the way. If you try to instal os to pure ssd, it's also will be with error. So conclusion don't use 860 EVO and 850 EVO with iMac 27 mid 2011 (I have core i5 3,1). So your SSD will work with USB 2.0 on your iMac, or need to buy thunderbolt ssd adapter or thunderbolt usb 3.0
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Where did you get this nonsense!
I've been installing Samsung 850 EVO & Pro SSD's in many different Mac's. The system I'm using right now is a 2011 27" iMac with a Samsung 850 EVO as its primary drive.
I think your real issue here is understanding how to properly setup a Fusion Drive.
さんによる
Different 850 evo and 860 evo in controller Samsung MGX/MEX - Samsung MJX, maybe it's influence to stability. How to properly setup a Fusion Drive - i know
さんによる
Thank you very mmuch for posting this. I am seeing he same issue -- tried to replace 2Tb original drive on a 2011 iMac 27 with a 2Tb Samsung 860 EVO and the OS loads successfully, but it keeps rebooting itself. My tech has been trying to solve it. I guess I'll need to go back to a traditional disk or find a different SSD that is compatible.
さんによる
コメントを追加
If you install a 3rd party SSD you will need to download software to enable the TRIM support. I have been using this program for the last couple of years Trim Enabler.
Otherwise totally go with the recommendations in the previous answer. Personally I am more partial to SSD's especially since the prices have only been falling. I highly recommend the Samsung 840 or 850 Pro drives.
Dual HD upgrade is the way to go!
このアンサーは役に立ちましたか?
スコア 1
12 件のコメント:
I changed my 27 inch iMac (mid 2011) to a samsung SSD 850 EVO, afterwards my hard drive fan went crazy (high rpm, 5500 rpm). Founf the easy fix for this, downloaded this app and configures it with one-click to "SMART":
http://exirion.net/ssdfanctrl/
Then it get the temp data some other way that are used in todays SSD's. Fan reduced to about 1500 rpm and quiet again! :)
さんによる
I forgot to mention that I didn't use an thermal sensor when I installed my disk... that's why I had to use the SW above...
さんによる
A Q - Sadly, fan control software is not a very good long term fix. Over time you'll kill your system. It's best in your case to use the OWC adapter cable: In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade.
さんによる
Over time answers do change and better ways are found as in this case
さんによる
Some good news here! OS-X 10.11 (El Capitan) restores TRIM services! Here's the details known so far: El Capitan Opens Door to TRIM Support on Third-Party SSDs for Improved Performance
さんによる
7件以上のコメントを表示
コメントを追加
I installed a 1 TB hybrid drive in my 2009 27" iMac, the reason I did this was so I could remove the sensor off the old 1 TB drive and put it on the new hybrid drive (SSHD). That way the temp sensor does not run the fans at super full speed.
Also at the time I read about SSD's they need to be purged once in a while, maybe not now but 3 years ago I think that was the case. So with the hybrid drive as it needs to it can purge the caching flash part of the drive.
In the end the programs and files I use all the time are right there and the stuff I don't use all the time is still in the deeper storage on the HD side, so it starts up quick and programs I use all the time open right up.
This seems to work well for me. I have a 2 TB drive on the time machine that I only turn on once in a while.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
For many this is a good half step! Back then SSD drives where expensive. Today the price of a 512 GB to 1 TB SSD has dropped to a more realistic price. For many a SSHD hybrid drive does make sense. If you want still more performance a dual drive setup either as discrete drives (SSD & HDD) or combining them into one logical drive by creating a Fusion Drive may offer a option.
Apple finally allowed 3rd party drives to leverage TRIM services within the MacOS. So now you can go either way having a SSHD swapping out your old HDD, or if you can swing it upgrade the HD and add in a second drive in this case a SSD. If space is not an issue then swapping out the HDD for a SSD also makes sense. That would give you the best performance.
But be careful! You'll need to put in the in-line thermal sensor if you swap out the orginal Apple drive with another drive which does not offer the needed internal thermal sensor connection.
さんによる
コメントを追加
@Dan - I've got a question about some of the information you've posted. Background: I have a mid-2011 21.5" iMac. In Disk Utility, the hard drive (factory-original Seagate ST3500418AS, 500GB) reports S.M.A.R.T. status as "failing." In researching how to properly replace the HD, I've seen all the discussion (here and elsewhere) about the proprietary temperature sensing firmware etc. that was added in the 2011 iMacs.
In your comments above, you mention a couple times that replacing the factory HDD with a SSHD would not require the OWC in-line sensor cable ("get a SSHD that has the builtin sensor and gives you similar performance of a SSD" -- 1/6/2015; "the SSHD has the needed built-in thermal sensor (you won't need the OWC cable)" -- 1/6/2015). But then elsewhere, you say that even with an SSHD, you'll still need the OWC in-line sensor cable ("Don't forget you'll need the OWC in-line sensor if you go with the SSHD!" -- 9/16/2017; "You still need the OWC in-line thermal sensor cable." -- 9/16/2017).
I'm not trying to call you out at all...I'm just confused--which is it? Could you clarify for those of us that might be in this situation? Are there any SSHD's that do have a built-in sensor and appropriate firmware, such that no OWC cable is required? If so, do you know which brands/models are suitable? I am trying to avoid buying the OWC cable if possible, given the somewhat steep price for such a small part ($40+). I would much rather spend that extra money on a larger/faster disk drive that already has a built-in thermal sensor.
Thanks in advance!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sorry, for not seeing your post sooner. Don't blame me ;-} Seagate altered things. The 2nd generation of drive had the in drive sensor enabled, I suspect Apple called them on it and it was disabled (firmware disabled). So all of the drives now sold don't have it enabled which is why you now need the OWC sensor.
さんによる
コメントを追加
Hi @danj , I went to a PC repair store and they told me that I do NOT need any thermal sensor cable to replace the original HDD with an SSD, because the SSD doesn't have the pins to connect it.
1. Do you confirm that I need a thermal sensor cable to swap my original HDD with an SSD?
2. Where do I connect the thermal sensor cable if the SSD doesn't have the right pins?
Thanks!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
@xfyk - I think he is confused ;-} YES it's NEEDED!
The iMac's all use a thermal sensor on or within the HDD to learn the temp of the drive so SMC services within the system is able to manage the heat. Different series of iMac's have done this differently over the years.
The 2011 iMac (either one) leveraged a set of pins (header) the drive makers had. Here the drive makers modified their drives to met Apples needs. So a real Apple drive has this special firmware & connections, any stock drive you buy won't have it setup as Apple is expecting. Here's a bit more: Rocket Yard - 2011 iMac HDD thermal system
As such your system will not see the needed signal and ramp up the fans going into fail safe mode. So if you put in a replacement drive (either a HDD or SSD you need to a special cable to add in the needed sensor OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. This cable is placed in-line with your current HD SATA cable and the thermal sensor is them placed onto the drive. This is the only way I replace HDD's in the 2011 models.
Using any other method to override the fans is very risky! As they tend to either kill the fans or overheat/thermal shock your logic board killing it.
さんによる
Perfect answer, thanks a lot @danj !!! A suggest: update your original answer with this information would be nice ;)
さんによる
コメントを追加
Hello,
I'm a bit lost: will the cable sold by iFixit be ok with the thermal control? Or should I go for the one sold by OWC? Is there any specific feature I should look for on the SSD itself before purchasing?
I'm really interested in changing my drive, but don't want at all the software solution to control the fans (program crashes: no control, what about Bootcamp, etc.)
thanks a lot! Pierre
このアンサーは役に立ちましたか?
スコア 0
12 件のコメント:
The issue here is the way Apple leverages HD's which have an internal temp sensor so the system is able to manage the heat created as the drive is used. SSD's while they do get warm don't get as hot as HD's and thats the rub here! So to your question you require a sensor and it needs to meet Apples requirements hence you need the OWC cable for a HD to SSD swap OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. You really can't use the standard SATA/Power cable setup without having to deal with the systems fan management. True, some people easily on created software to override the fans. Over time its been proven as not a wise choice as the systems lifespan is greatly reduced as the system can't dynamically adjust the fans to manage the ups and downs of heat buildup. I won't put a straight SSD in the newer systems as the primary drive without the cable or get a SSHD that has the builtin sensor and gives you similar performance of a SSD.
さんによる
How about going with a SSHD (hybrid drive)? It will give you the zip you're looking for with the SSD and still offer the deeper storage a HD offers. Unlike the SSD solution (swapping out the HD for it) the SSHD has the needed built-in thermal sensor (you won't need the OWC cable). Review this: Seagate Desktop SSHD. Your other option here in the '11 iMac is setting up a dual drive here you leave the HD alone and add in the SSD using the spare SATA & power connections on the logic board. Review this IFIXIT guide: Installing iMac Intel 21.5" EMC 2428 Dual Hard Drive Kit.
さんによる
I should point out I don't do HD to SSD swap outs, I will only do HD to SSHD as I have found most people end up getting an external HD to make up the loss of storage (which is less efficient) or come back wishing they went with a bigger SSD ($$$). Given the cost difference I move people to the SSHD solution as being the best here or I'll do a dual drive setup (HD and SSD) when the system allows it (as in this case).
さんによる
Thanks Dan. Indeed my intention is to add a SSD (and keep my current 1To HD). But I still read many comments of people having problem with their fan. So to summarize:
- replacement of HD --> OWC cable with temperature probe or "Mac-compatible" drive with any cable
- installation of a second drive (SSD) --> any SSD + iFixit cable will do the trick
Final question: do you know if I can install Windows (bootcamp) on a partition of the SSD if not installed as the primary drive? I understood the PC are less flexible when it comes to this kind of questions...
さんによる
OK, so you're going dual drive thats fine ;-} So the SSD with be your primary drive correct? Then you'll install BootCamp and Windows on the SSD (with your Windows Apps) or you'll need to setup a Fusion drive config which is bounding the two drives as one logical drive, letting OS-X manage where the files go. The problem you'll face here is the side of your SSD may not be big enough if you setup a dual drive setup (each independent of each other) you need to have both OS's (and any other OS) on the SSD with the Apps (OS-X & Windows). For both OS-X & Windows you'll need to leave about 1/3 (no less that 1/4) of the SSD free for temp files, virtual RAM and/or Paging files. A Fusion setup can help here but you're then loosing some of the performance you wanted with the SSD. At that point you'll might as well go with the SSHD. You'll need to do the math on how much space you'll need to buy (the SSD) to make it work for you.
さんによる
7件以上のコメントを表示
コメントを追加
Why replace the existing HD with a SSD, when it is possible to install the SSD and keep the original HD?
I did it on my iMac, SSD is now my startup disk for both MacOS and Windows using BootCamp.
Only question: How does the TRIM work for partitioned drives? Do I have to enable it on Mac & PC, or just Mac?
Thanks!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I think your first question has ben answered above: No need to replace. As for TRIM services this is a low level function on how the OS handles clean up on the SSD. In the case of a partitioned SSD running different OS's the running OS will deal with its partitioned files clean up. In the case of BootCamp (a type of Virtual Machine), the Mac OS handles the calls from within the VM to the SSD drive.
さんによる
Not all of the Mac OS's offer TRIM services, the newest versions Mavericks & El Capitan do. All you need to do is enable it from a terminal command line argument if you have a 3rd party SSD, otherwise its already enabled with the Apple SSD's. MS Windows has it on by default.
さんによる
コメントを追加
I was thinking about updated my mid 2011 iMac hard drive to SSHD. I was looking at the Seagate 1TB Gaming SSHD SATA 32GB NAND SATA 6Gb/s 2.5-Inch Internal Bare Drive (ST1000LX001). I liked this, because it features a 32GB SSD vs the 8GB in the desktop version. I know I'll need to buy a mounting kit with it since it is a laptop hard drive, but will I need to worry about the thermal control issue? Thanks.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Why don't you just bite the bullet here and get a SSD and add it to your system via the spare SATA port? I think you'll get a better end result.
Here's the IFIXIT guide you'll need to follow: Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit. Other than the drive you'll need this kit: iMac Intel 21.5" Mid 2011 Dual Drive Kit.
さんによる
If you go with the main drive you'll encounter a few different issues: You'll need an external thermal sensor OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. If you use a 2.5" drive you'll have problems fitting the adapters cable. In addition, you'll need an adapter frame like this one: OWC 2.5" to 3.5" Drive Adapter Bracket
Frankly, I think you should stick with a full sized 3.5" drive as they are quicker if your primary drive needs replacing.
さんによる
Thanks. The discussion above made me think that using spare SATA port would be a bit outside of my expertise. But I don't really think it would be, I was just feeling lazy. Thanks for your replies.
さんによる
コメントを追加
I was thinking about updated my mid 2011 iMac hard drive to SSHD. Will I need any special cable as well as mounting kit?
Reiko
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you read the accepted solution for the info it has? Reread it, as it has all of the info on the parts you'll need here.
さんによる
コメントを追加
Hello Dan, Just so i understand your amazingly thorough post, if I don't want to use the HD drive in my mid 2011 21.5 iMac, do I just follow the instruction provided, adding the SDD drive using the optical thermal sensor from OWC?? My confusion is that your link shows you how to add an SSD drive to make a dual drive with the HD, but when you mention the option of not using the original HD, you use the word "replace" and then mention the use of the OWC optical thermal sensor. Am I removing the old HD and replacing it with the new SSD or am I adding the new SSD keeping the old HD,but using just the SSD? hope that makes sense. thanks in advance.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
I think you got a bit confused here ;-} The two directions were swap out HD for SSD OR Add SSD.
- For the swap (replacing your current HD) you'll need the OWC inline thermal sensor as the SSD does not offer the needed interface for the SMC thermal services of the system.
- In the case of the Add SSD, no thermal sensor required!
OK, now to really confuse you!
In addition you can even swap out the optical drive with a special drive carrier to then hold a 3rd drive! This is what I think got you here as you were talking about the optical drives thermal sensor.
Here is the older 2010 dual drive setup which you could do 'in addition' to the above but remember, you loose the optical drive which is why I don't do this in this series: Installing iMac Intel 21.5" EMC 2389 Dual Hard Drive
Hope it makes sense now!
さんによる
Lastly, the comment on using a SSHD was if the current HD drive was dead or just undersized. It offers deeper storage (just like a HD) and yet has some zip like a SSD. It offers a cheaper solution and less work than the dual drive config.
SSD are great! Don't get me wrong.
But the cost is a killer $$$ when you need more storage and only using a single drive. This is where a 512 GB or 1 TG SSD are just to costly for most. A dual drive setup (HD & SSD) is a good solution! Here you're using the speed of a smaller SSD for your boot up and then the traditional HD for its deep storage.
But wait a sec here... Didn't I just say the same things when describing the SSHD?? Yep! Its almost the same thing! The two differences are the drive deals with where the files go in the SSD cache or on the disk, where here you need to manage it across the two physical drives. But wait a sec here... Isn't an Apple Fusion Drive doing that! Yep! And you could convert the two drives into it. And the second is the size of the SSD cache is fixed on the SSHD drive.
さんによる
Hey Dan, thanks for your answer. Do you recommend any particular current SSD besides the seagate? I was looking at this Samsung 1 TB SSD 2.5 inch mz-75e1t0Bam. not sure if link will work. It's only $320. I'd like to swap my current 1 TB hard drive out for this one. I have the mid 2011 21.5 inch iMac. Think I should keep my old slow HD? Thoughts? Thanks again for your time and patience.
https://www.amazon.com/Samsung-2-5-Inch-...
さんによる
As I sent this I realized my mistake in writing you. I know you recommended the SSHD seagate model, but do you recommend any particular SSD if i went that route? How do the SSHD work with regards to how much SSD space is set aside for often used files, cache, etc.. and how much is HD for deeper storage? I'm assuming the SSDs are double the speed, but see your point about cost. Costs for SSD have gone down. I do have a 4 tb external thunderbolt hard drive as well. Sorry for my misunderstanding. Thanks in advance.
さんによる
I think you mis read what I stated here. I won't do a single SSD drive config in this series. I would do a dual drive config! I would go with a smaller drive 256 GB or 512 GB for the primary SSD drive (using the dual drive setup). As to who's drive we use Samsung EVO drives.
If you want a single drive setup (replacing your current HD) I would go with the Seagate SSHD.
さんによる
3件以上のコメントを表示
コメントを追加
Hello!
I am hanging on for the next desktop release due late 2017 (arrgh) meanwhile I have a slow mid 2011
27 - inch imac. Will installing a SSHD speed it up or should I just say goodbye and rent a machine while I wait? Halp.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Sorry for not seeing your comment sooner.
I would recommend adding the SSD unless your current drive is overly full (need more storage), then going with a SSHD makes sense. Don't forget you'll need the OWC in-line sensor if you go with the SSHD!
さんによる
コメントを追加
Wondering if this WD drive will work to swap without any additional cables etc.. https://www.wdc.com/products/internal-st...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, the WD SSHD will work as a replacement drive for your current HD. But! You still need the OWC in-line thermal sensor cable.
さんによる
コメントを追加
I'm sorry as I realize this is an older thread. So I failed to do my due dilligence prior to buying a new SSD for my wife's Mid 2011, 21.5 iMac.
I wanted to know if this is possible. I want to install the SSD in the spare bay behind the optical drive. prior to doing that was thinking I would clone the HDD to the SSD, then wipe the HDD. This way the iMac runs the OS from the SSD and has another storage drive. it is Mid 2011 model so I do not have much faith the HDD has much life left in her so want to transfer the OS and other valuables off of it.
Figure I will use it for nonessential things. I have a 2 TB Lacie external HDD that I would place anything super important onto.
Does this plan sound too difficult or is it possible?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Technically there is no bay. All you're doing here is mounting the SSD to the case using double sided foam tape. Which more than enough to hold it.
I think you've got to complex a process here. If your HD is still working just down load the OS installer on to the HD, open the system install the SSD. Then run the OS installer and install a fresh copy of the OS on the SSD leveraging your HD. Once done use the Migration Assistant to copy over your Apps to the SSD then go into the system prefs to alter the startup to the SSD.
If your HD is getting ruff, you'll need to either install a new drive or transfer the SSD over to the HD location and you'll need to install the OWC in-line thermal sensor to replace the custom in drive sensor.
さんによる
Good evening Dan,
Thank you for your help. Just wondering why would I need to move the physical location of the SSD? That also seems a bit more complicated than what I was thinking for the dealing of the drives for boot would be install the SSD, the use disk utility to create a restore (clone) to the SSD, then use disk utility to erase (wipe) the HDD, boom got a new spare storage drive until it dies. But once it dies I just planed on leaving it be. I'm assuming that's a no go?
さんによる
If you have a useless leg it often makes sense to cut it off. Having a dead drive is similar. It makes little sense leaving it. But we do have a small issue with its internal sensor which the systems SMC services uses, so if you pull the drive the missing sensor creates an issue. If you were to move the SSD over you would still have an issue as the sensor output is not present on the SSD. Which is why you need the in-line OWC sensor.
I do like having a dual drive setup! It allows one to have the SSD being the boot drive & App drive and then leverage the larger HDD as to data drive.
Using an external while important as a backup of your data, is not always the best I/O (speed), FireWire and USB are slower interfaces, Thunderbolt in its 3rd generation is faster than SATA III (6.0 Gb/s) internal I/O your system has. The older generations is almost matching the internal SATA port but its getting hard to find the better drives. Which is why I would go with the internal drive.
You may have miss understood me. I was implying your steps you had outlined as being overly complex needlessly. No need for cloning, Apples Migration Assistant utility is by far better!
さんによる
コメントを追加
I have an old 21.5" iMac 2011, the hard drive works a bit slowly and produce constant noise from rotating parts. I read through the all comments here and I think a good solution can be this option: https://eshop.macsales.com/item/OWC/KITI...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
That works! But, its on the small side. If all you are doing is web surfing and simple writing it will be fine. I would go with a larger drive 500 GB or 1TB.
さんによる
Thanks Dan, for web surfing 128Gb is enough in my case. Although, the larger drives could be installed, I guess
さんによる
コメントを追加
回答を追加する
Alper Gunay さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 34
過去 30 日: 189
今までの合計 184,739
