メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
How do I disable a key on my keyboard
I spilled some milk on my keyboard and want to disable the command key and maybe change another key to delete because that doesn't work now also. Is there a way of doing this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
7件の回答
ベストアンサー
Take a look at the OS X system preferences under Keyboard there is a button on the lower-right named "Modifier keys" where you can define which actions should be taken by the modifier keys (caps-lock, ctrl, cmd,...). There's an option to disable the cmd key.
And with the free software DoubleCommand you can swap the delete key with the Caps Lock key.
http://www.simplehelp.net/2008/09/08/how...
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
+ good, but what about removing the offending keys and cleaning?
さんによる
Michael could try to remove the key and clean the milk under it but when a keyboard key has no response after a liquid spill the problem is inside the keyboard and not under the key. The best move is to replace the whole top case with a clean used one. You can find one under $50 on eBay.
さんによる
will this work for arrow keys?
さんによる
Yes, you can use software for this: https://youtu.be/m_5vQehbcds
さんによる
コメントを追加
Lift the key
Cut off the silicone nipple with a pair of dykes or a scalpel. If the key does not compress the nipple there will be no "action" of the key.
If this answer is acceptable please return and mark it.
Good Luck,
N.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I used Karabiner for this. But this only works when you're already logged in, só I had to change my password for the key `(the same with ˜). That's the only key not modified. Worked well... So far.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Here's some crazy guy who teachs you how to clean it up.
https://www.youtube.com/watch?v=LCT-CldP...
さんによる
karabiner helped me a lot!! thank you man!!
さんによる
thank you, this is exactly what I was looking for
さんによる
コメントを追加
hel\p me my dash bbutton\ is stuck and co\nstantl\y appears when i am typing .\.\ i have taken the key cap o\ff and brok\en the nippl\e but this stil\l\ happens, do\es anyon\e have any advise, can I disabl\e this key?
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
\\\\i have the same thing, did you fix \your\s?\\\\\
さんによる
Me too but with the number three key. It randomly presses, which is super annoying. I haven't broken the nipple because I'm not sure how but I'll look it up after this. What's annoying is whenever I watch youtube, when the number three is pressed, the video would automatically go to the three tenth mark of the video. So if the video is 10 minutes long, it will randomly go to the three minute mark randomly as I'm watching. Super frustrating. Has anyone figured this out yet?
さんによる
Ok I can't find a video on how to break the nipple of a key on youtube lol welp
さんによる
i hav\e the same thing but after a year it is no\ l\o\nger that intense as it was befo\re
さんによる
\\\\\\\\\\\\\\\\\\\\\\\\i also have the same p\roblem! anyone find an answer?
さんによる
2件以上のコメントを表示
コメントを追加
I have almost the same problem, but it's Shift that is stuck so I won't be helped by the standard system settings in os x.
I actually (in some type of anger) tried cutting the silicone nipple off myself, but it's still pressed. Can't really tell whether it's the L or R shift. I decided it was the left because it didn't work at all. The right one responds.
Nothing have helped so far, and I tried installing keyremap4macbook but making changes there makes no difference what so ever, it's still active(?)
The biggest problem with having the shift constantly pressed is that on reboot, the computer chooses the internal keyboard instead of the external, which works just fine when the computer is on. But starting the computer with shift pressed turns it on in safe mode, which is horrible. No sound, no watching video etc.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
i have this same problem; actually that is why i can·t write in small letters
about the reboot; if you press (for example) fn; ctrl; alt; cmd all together the system somehow think you have somehting pressing all the keyboard and starts in a normal way
now trying the way to deactivate this shift :(
さんによる
If you hold down the Option key while rebooting, it will not boot in safe mode. From there, you can insert an external keyboard and hopefully log in. Sometimes you may need to hit the Caps lock key on your plugged in keyboard to over ride the shift key.
さんによる
コメントを追加
Hey! I'm having this same problem. I replaced my keyboard and everything worked properly for about two weeks before the problem came back. Is it possible that reflowing the solder on my logic board could help (this worked when I had the black screen of death)? Thanks!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Im getting crazy over this, the left arrow button suddenly activates like im holding it in, so in videos it jump back to start, impossible too write anything. It actually helps to smash the $@$* out of it in frustration, it might work for some hours or just seconds. If I dont find a solution fast, i might smash the whole thing with a hammer next time. Like its a older pro, so really not interested in buying and paying lots for repairs. So, can you deactivate a button or what? Times like these i wish a bought some garbage microsoft infused plastic, but it probably would not lived thru the first anger attack.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
michael Fordham さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 45
今までの合計 67,613
