メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore Elite HE3は、Kenmore製の容量7.2立方フィート(約204リットル)の電気乾燥機です。
Dryer won't start Error Code F70
Just had a Thunderstorm and lightning hit very close to our house blew 2 circuit breakers. I reset them and everything came on in the affected rooms. When my wife tried to start the dryer it wouldn't start and has an error code of F70 flashing. What does this mean and wan I fix it or do I need a technician?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
1 件の回答
ベストアンサー
Doug, F70 means check harness connections at the machine control and at the console electronics. If your connections are fine to the machine control board and the console electronics, then you may need to change the machine control board. Unplug your dryer first and leave it unplugged for a while to see if it resets It is below the top panel on the left hand side of the dryer panel. I attached the tech sheet for the dryer to the bottom of this page. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
I replaced a circuit board run as described "https://www.youtube.com/watch?v=eWqrn5kl...: However, I did not properly seat one of the plugs. I reopened dryerthe board and checked the plugs. Once I found the loose plug, I re-seated it properly and the dryer came up perfectly.
Thank you so much for this excellent video.
さんによる
Thanks to this information above I was able to get mine going too!!!! (Thank you)
さんによる
coding F01 is iqual a F70?
さんによる
コメントを追加
回答を追加する
Doug さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 36,021
