Why does my iPhone3G only works with external MIC/Headset?
My iPhone 3G only works with external mic/headset.
People cannot hear me speak, nor does the Memo Recorder work, except when an external mic/headset is plugged in.
Thank you
この質問は役に立ちましたか?
2 件のコメント
I installed a new docking PCB, but the problem is still the same.
I can hear the caller, but the caller cannot hear me.
In addition to that the Memo Recorder on the IPhone does not record any sound - except when I plug in an external mic.
Could there be a problem with the external mic connector in that it has a defect that causes the external mic connection to override the internal mic, always?
Henri Johnson さんによる
that sounds baaaaaaad - can you tell me sonething about the phones history? fluid damages, dropped, overrun... - if the internal mic isn't working, but the earpiece is (we have to rule out that the phone isn't stuck in headphone mode) also the speaker/buzzer in the dock is working normal - then there is a problem with the audio codec ic or the connection between the dock connector and the audio ic
markus weiher さんによる
