Engine starts then dies everytime
When I start my truck it starts and immediately stops. What would cause this?
I had the same problem , I changed the fuel pump and it has not turned off since
この回答は役に立ちましたか?
Passlock/passkey sensor needs to be replaced. This is the cylinder housing your key switch goes into.
この回答は役に立ちましたか?
Check antitheft passlock module-located behind ashtray compartment. My circuit board was burnt in 3 places
この回答は役に立ちましたか?
You may have inadvertently turned the key on and left it on for just the right amount of time then turned it off where-by starting the key learn sequence in GM's Vehicle Anti Theft System or VATS . The VATS may not be programed to the key now and all you have to do is go to this link and follow the directions.
My ignition on my 1999 Tahoe was vandalized, and the Anti-theft is
Good luck and I hope it works.
この回答は役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 641
The fuel pressure is good, changed plugs,wires,distributor cap. Ran well the day before and next morning battery was dead. Charged up bat. and then motor would start and then die each time, over and over, not doing anything else.
patomccoy さんによる
