My Samsung Galaxy Note II Clone is not working?
Hi, I have problems on my phone Note II clone . I just make root in my phone, after that I reboot my Note 2 then do not on. Please help me.
It is probably because it is a clone. Which really means a cheap imitation version. No offense. However did you make sure that the firmware was the exact same. The root for the actual note 2 might not have been compatible for your phone. Also did you install a recovery on the device?
このアンサーは役に立ちましたか?
I'm not sure for recovery in my phone. But I try on still not working. Sometimes I'm give up but I need my phone.
このアンサーは役に立ちましたか?
If you have gt-n7100/7102 you must found the corect driver for display and motherboard. My phone after 2 years it's alive.
kernel_konka77_cu_ics2
preloader_konka77_cu_ics2
uboot_konka77_cu_ics2
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 323
