メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
power comes on but screen remains black
When I power on the computer the light on board comes on and I can hear the power supply working and the hard drive working but the screen ramains black. I opened the computer saw the power supply working but the fans were not running.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
It is an iMac Intel 20" EMC 2133
さんによる
コメントを追加
2件の回答
最も参考になった回答
Well since you have already opened the computer. Take a look at the diagnostic LEDs. They are located to the right of the RAM.
LED #1
• Indicates that the trickle voltage from the power supply has been detected by the main logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2
• Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3
• Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED #4
• Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
try to reset the SMC (System Management Controller)of the iMac
1. Shut down the computer.
2. Unplug the computer's power cord.
3. Press and hold the power button for 5 seconds.
4. Release the power button.
5. Attach the computers power cable.
6. Press the power button to turn on the computer.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
courtney さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,479
