メインコンテンツにスキップ
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117回答 すべてを表示
Need to run bootable copy of desktop on storage to my iBook.
I want to copy my bootable copy from my old desktop to my iBook. When I change the startup disk preference to select the LaCie the iBook ignores it.
The desktop crashed (poor old eMac) and I can't find my system disks for the 10.4.
I made the copy of my hard drive on the LaCie with Super Duper before it died. Super Duper assured me that I had made a bootable copy.
Now that I need the LaCie to boot the Laptop (so I can copy my stuff from the desktop to the laptop) - it won't.
The LaCie is running 10.4.11 and the iBook is running 10.3
I bought the laptop as a notebook to carry when I went to get coffee. I never thought it would have to be the mainstay for my house.
Does anyone have an idea as to how to block the 10.3 on the laptop and allow 10.4 to take over from the LaCie.
Sad story, but true. I lost 15 years of work when my office computer and the hard drive both melted on the same day. Neither disk was recoverable. $2000 went down the tubes with the work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
did you press the option key right after you powered on the iBook and selected the firewire drive ? - that would be the normal way to start from the FW LaCie
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can boot from your LaCie, sometimes it can be tricky on older machines running PPC.
First
-reset the Open Firmware
-Start the computer holding down "command" , "option" , "o" & "f"
-when the text shows up type "reset-nvram"
press enter
-then type "reset-all"
press enter
The computer will restart, hold down "option" and make sure the LaCie is plugged in to the iBook. You should now see your LaCie as a startup disk. select it and press enter to boot from the drive.
..done & done..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 824
