メインコンテンツにスキップ
Released at 2013, September. Display size - 480 x 800 pixels, 4.3 inches. Internal memory - 4 GB, 1 GB RAM. CPU - Quad-core 1.2 GHz Cortex-A5, GPU - Adreno 203
Why can I not increase the brilliance or back light
i have fitted a new screen and digiliser assembly and all is working i have reset to factory settings but the problem is the back light or brilliance is very dim i have gone into settings and it is on maximum setting i have also tried on automatic setting no differance can you help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
can any one help
さんによる
コメントを追加
1 件の回答
Hey grout705,
Did you try to change the backlight screen timeout, go to Settings - Display - Sleep. Then choose the screen time out duration.
You can also tell the phone screen to always stay lit when it is plugged in via USB. Go to Settings - Developer Options. Then check Stay Awake.
-If you tried those please comment to let me know.
*Hope this helps*
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have the same problem...
Changed the digitizer and lcd unit, all works fine (after a terrible 10.000 times of in and out) but now the backlight is very dim.. Did everything you said but still no solution
さんによる
コメントを追加
回答を追加する
grout705 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 634
