メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook won't start with installed battery
Hello
My Powerbook won't start with installed battery.
If the Battery is not installed the powerbook starts normal.
I did all resets i read (PMU, SM*, etc.)
With a new battery it is still the same.
Wich part of the Book is broken?
The power supply is noise *feeep* when plugged in but seams to charge the battery.
PRAM?: With no installed battery it forgets the date after a while with no power cord plugged in
DC-IN Board?: Is that responsible for power management?
or the logic board?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Well you do have a couple of problems here:
First you'll need to replace the PRAM battery if your model has it. Here's the guide to get to it: PRAM Battery & USB Board Replacement. Some of this series had a clock chip which had it's own battery internally on the logic board.
I do think you have a logic board issue with the charging circuit. The DC-In board does not have any of the charging logic on it. This could be a big job to diagnose and repair.
This system is quite old. I think your money & time would be better spent on a newer system. Don't get me wrong here in its day is was one !@#$ of a system! I had the titanium version for quite a few years.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
nudge さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 13
今までの合計 391
