メインコンテンツにスキップ
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153回答 すべてを表示
How to remove the all bolts of thermostat
how to remove the all bolts of thermostat nissan altima 2002 3.5l.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
consueloscott1972, I am a bit confused by your question. I am wondering which bolts you are referring to.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
consueloscott1972, try this:"
Before servicing the vehicle, refer to the Precautions Section.
Drain the cooling system.
Disconnect the negative battery cable.
If equipped with an engine undercover, remove using a power tool.
Remove drive belts
Remove water drain plug on water pump side of the engine.
Disconnect lower radiator hose.
Remove engine coolant inlet and thermostat assembly.
NOTE
Do not disassemble engine coolant inlet and thermostat. Replace them as a unit, if necessary.
To install, reverse removal procedure.
NOTE
Install thermostat with jiggle valve facing upward.
Fill the cooling system.
After installation, run engine for a few minutes and check for leaks.
From here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
consueloscott1972 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,871
