メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides, manuals, and troubleshooting help for a wide variety of Nikon lenses.
Remove a stripped lens mount screw from Nikon 300mm f/4.5 AI-s lens?
I'm trying to remove the lens mount, so that I can disassemble and clean a vintage 300mm lens (something is on the interior elements--possibly oil from an ill advised attempt to lubricate a sticky focus mechanism) . Problem is, the screws holding the lens mount on are JIS, not phillips, and one of them is now stripped--the stripped screw is size 00. The other screws are can be screwed out quite easily with JIS screwdrivers. Tried the rubber band trick.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Try heating it up a bit (heavy duty soldering iron), the loctite used on the screws will soften a bit which might allow you to get it out.
Otherwise its time for a drill to pop the head off. Then you should be able to grasp the shank of the screw with a pin vise or carefully slot the top for a straight blade.
Mind the metal flakes as you don't want them to get in to the diaphragm control mechanism.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
jerwin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 27
今までの合計 1,565
