メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
152回答 すべてを表示
締切られた回答
Inaccurate GPS on ipad 2?
I have an iPad 2 w/ 3G that has a consistently accurate GPS. It always seems to be off by a 1/2 mile or so.THis occurs when the wifi is turned off and the ipad is relying on the SIM card and internal GPS.
Any thoughts of what would cause the problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Where are you in the world?
さんによる
Halifax, Nova Scotia. It's definitely the device as my i phone is perfectly accurate. The iPad is always off by a half mile distance in comparison though.
さんによる
Well, you are up there near the pole ;-} Even still if your iPhone is showing an accurate location I would say your iPad needs repair. Sadly, it sounds like the logic board has a problem. Was it damaged at one point (dropped or had gotten wet)? Was it serviced by someone?
さんによる
It's one I've fixed up. I've replaced the digitizer, power /volume flex and wifi antenna and straightened out the frame around the dock connector.
No signs of any other issues with the logic board though. Everything else seems OK. Wonder if a system wipe & restore would help?
さんによる
Can't hurt to do a wipe & restore. I think this is a timing issue within the cellular chip were the GPS signals are processed. Here's a good write up: How Global Positioning Systems Work.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Some areas are harder to triangulate as the satellites are close to the horizon (north & south polar areas).
When you are in a dense city triangulation can be tough as well as the line of sight can be blocked by large buildings.
This is why a hybrid solution using satellites, Cell towers & WiFi AP's is used to improve the accuracy of global positioning.
Also remember the public GPS signals are slightly phased over the military GPS signals which can do ionospheric correction (8 meters/26 feet or more near the poles). Here's the US Governments web site that gets into all of this: GPS Accuracy
With that said, compare your iPad to another iPad (or other like GPS device) to see if the GPS services are damaged. If they both react the same the issue is your location.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 533
