メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
596回答 すべてを表示
Serial No. went missing on my MacBook Pro
Hey guys!
Have you ever met this?
I have been recently suffering from nVidia issues on my mid2012 i7 15" MBP. It freezes all the time, have little squares, and lines on screen, when frozen. It wouldn't be a problem, because I have Apple Care, BUT!
As far as I am experiencing these issues, my motherboard forgot it's serial no. It's like if I had already changed my logic board, it says "System Serial#".
I am working with Macs, I am repairing them since 2010, but I've never seen anything like this, and this machine's logic board hasn't been changed, that's for sure, bcz it's my own.
I attach some pictures, where you can see, that hardware monitor app recognizes that I have "switched" computer, but remembers an older machine (with my serial no.), which is quite similar.....
https://www.dropbox.com/sh/0xrdv6o3f700q...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Would you mind giving us full serial number off the bottom of the machine.
さんによる
コメントを追加
2件の回答
ベストアンサー
Did you check the systems firmware? Here's Apples TN on how to check and update: EFI & SMC firmware updates for Intel-based Macs
What happens when you boot the system off of an external HD or thumb drive which you know works correctly on a different like system? Does it still mess up?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Will this solution work on a Mid 2013 MacBook Air 11”?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Time marches on!
This solution was workable with the older OS-X OS's. I'm sure you are now using a much newer version of OS (MacOS) I would recommend you give us all of your systems details in a fresh question here: Ask a Question
さんによる
コメントを追加
回答を追加する
Andras さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 4
今までの合計 11,257
