メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Stripped heatsink T5 screw! What to do?
I was following the "remove heatsink" guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torx screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
I tried with the two way you proposed but nothing... to be honest i'm stuck on the pentalobe now, i can't open the bottom case thanks to that screw!! my pentalobe screwdriver make a hole in the rubber band so it becomes useless... i don't know what to do! I think i will use a dremel to cut to brake the pentalobe screw and then when i'm in i will make a cut on the torx one to use a cut screwdriver.
Again sorry for my bad english :)
さんによる
with an hammer?!? but i destroy my pc doing this!! :O
さんによる
Purchase a screw extractor bit. I had the SAME problem on a Mac and had to resolve it this way. The cost is under $10 and a little effort on your part.
さんによる
@Shaggot96 Try nipping off the sharp tip of an exacto knife. Put in stripped hole and turn. If it slips trim a bit more of the exacto blade. It worked for me!!! Cool.
さんによる
コメントを追加
5件の回答
ベストアンサー
I had the exact same thing happen to me on a Mac. I used a screw extractor (about $5 from a local tool store). It worked great.
I hate those darn T5's and smaller screws.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Hey bro, what mm screw extractor did u use?
さんによる
DId you ever find out the extractor size?
さんによる
I don't remember the exact size but I bought a 3 pack of 3 different sizes. The small was only slightly larger than the T5. The bit is tapered so it fit the screw hole.
さんによる
コメントを追加
最も参考になった回答
Use a 1.3mm flat head bit. Might have to give a small amount of force but it worked for me.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I had to use a Dremel to get the last three T5 screws out, file it down until you can use a flathead screwdriver.
さんによる
Yes thank you! had same issue, small flat head did the trick Now where to get replacement 3.5mm Torx 5 screw ...
さんによる
コメントを追加
First try a different bit of the same size as your T5 bit is most likely stripped. If that does not work, this is the trick I sometimes use: take a rubber band and put it over the screw, then use a marker to indicate where the screw is under the band. Put the T5 bit into the marked off area and try to loosen the screw.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Try to put a small amount of superglue on the end of the screwdriver and carefully insert it into the screwhead. Allow it to sit for about 1 hour and then try to remove the screw.
さんによる
コメントを追加
First get a flat head screwdriver and give it a couple of taps with a hammer and see if you can undo it that way
If you are going to use the dremel just use it to cut a small grove in the head for a flat screwdriver instead of breaking the screw with it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
A hammer on a T5 screw??? Yikes.
さんによる
コメントを追加
I hate Apple. They have this garbage hardware dressed up in their software. I tried taking the screws out to replace the battery and they ALL stripped and now its garbage. Can't change the battery. And for the record, I am not some nit-wit that can't handle a screwdriver of any kind, I work on computers all the time. But this macbook pro t5 screws really screwed me. Bought a new SSD and RAM which where both easy to replace and then this battery screws me. Garbage. Garbage. Garbage. I will never purchase another Apple product. I lie, I'll buy some Apple stuff. I got wrapped up in my emotions. Still though, cheap a__ __ T5 screws. My lenovo has better quality screws on it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shaggot96 さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 97
今までの合計 17,935
