Stripped heatsink T5 screw! What to do?
I was following the "remove heatsink" guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torx screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
この質問は役に立ちましたか?
4 件のコメント
I tried with the two way you proposed but nothing... to be honest i'm stuck on the pentalobe now, i can't open the bottom case thanks to that screw!! my pentalobe screwdriver make a hole in the rubber band so it becomes useless... i don't know what to do! I think i will use a dremel to cut to brake the pentalobe screw and then when i'm in i will make a cut on the torx one to use a cut screwdriver.
Again sorry for my bad english :)
Shaggot96 さんによる
with an hammer?!? but i destroy my pc doing this!! :O
Shaggot96 さんによる
Purchase a screw extractor bit. I had the SAME problem on a Mac and had to resolve it this way. The cost is under $10 and a little effort on your part.
chuckbalogh さんによる
@Shaggot96 Try nipping off the sharp tip of an exacto knife. Put in stripped hole and turn. If it slips trim a bit more of the exacto blade. It worked for me!!! Cool.
robbie cavolina さんによる
