メインコンテンツにスキップ
スピーカーとスピーカーコンポーネントを含む、サウンド生成するデバイスの修理ガイド
2703回答 すべてを表示
Jawbone Jambox will not charge or enumerate on USB?
Listened to my jambox on the way home. Turned it off when I got home. Went in the house and tried to turn it on again and it would not come on. I was not getting voice message from the box that battery was low. But I still tried Charging it. It would not show charging indicator. Tried to soft reset it to the PC but would not enumerate on USB.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Sounds like your PC's USB port power service fuse is blown.
If you have the correct USB charger give that a try. You may also want to try a different USB cable (maybe bad) which caused the fuse to blow in the first place.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
No. My PC is fine. And so is my charger. It will charge other devices. It is a standard 5V 500ma charger. Industry standard.
The problem is the Jambox will not power up. Something has died.
Switch, Battery, or Circuit board inside.
さんによる
Sadly, these are not really serviceable if the unit its self has a problem. You could try talking with Jawbone to see what they can do for you.
さんによる
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,741
