メインコンテンツにスキップ
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125回答 すべてを表示
Why is my tab not charging with black screen
guys please help! when I turned on my tab it hang in "SAMSUNG GALAXY TAB 7.0" and so i restart it again by holding the power button 10 seconds and it keeps oin restarting it wont turn off. because it's still hang I hold the power button and the volume down for 10 seconds and then I was glad because it finally turned off. but when I push the power button again it won't turn on and when I charge it, it won't show any signs of charging it's just have a black screen. I'm going crazy please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
open check the straps in back
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi,
Check your charger and cable first. Don't try to charge it with from the laptop's USB.
Do you have a reaction from the tablet when you try to enter the Android recovery menu (Volume UP + Power button), or Download mode (Volume Down + Power ON)? If not, try to connect it to the PC. If the Windows can't see connected device, then you have a hardware problem and you need a help from a specialist.
Regards.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
That worked for me Thank you!
さんによる
コメントを追加
Press power and volume buttons all together and hold for 15 seconds.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I've barely used my tablet and charged it up fairly regularly. The last charge was with a Powerbank - to test that the powerbank was working; I didn't fully charge it, just tested it for 30 minutes. After that, when I next tried to charge the tab with the normal leads, I got a message to say that the battery was overheating, so I stopped. I charged it but anytime I turned it on the battery drained really quickly.
I tried charging it today and the screen has gone black. Just tried the above .. the screen flashed on briefly after plugging it in to my laptop and pressing Android Recovery mode but actually never came on.
should I just take it to a 'specialist'
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
no throw it in trash can mine the same i going to stomp the crap out of it
さんによる
コメントを追加
I came on here as I have same problem thankyou so much yeeeha it worked x
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kate さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 27
今までの合計 11,711
