Link to Mid-2010 2.66 GHz Logic board
Hi,
In your replacement guide I see no link to purchasing a mid-2010 2.66GHz Intel Core i7 board.
I believe it was a new spec at the time.
You reference a 2009 board, but is that the same?
Thanks
/Stephen
このアンサーは役に立ちましたか?
yes, that is correct.
Thanks.
Amazing they still are so expensive... 1100 $
Here's another good source: PowerBookMedic a used board is about $600
DO NOT buy 820-2850 boards of any kind, they all wind up kernel panicing for no reason. Apple hasn't even figured this out yet. At least 2011 820-2915 boards work after replacing the GPU, 820-2850 just belong in a furnace.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,370
What are the last four digits of your computers serial number? That will help us to properly identify your hardware and which board you have/need.
oldturkey03 さんによる
Hi. Last 4 digits is: 5AGZ
Stephen Odgaard さんによる
MacBook Pro "Core i7" 2.66 15" Mid-2010 2.66 GHz Core i7 (I7-620M)
Intro Date: April 13, 2010 Disc Date: February 24, 2011
Order No: MC373LL/A Model No: A1286 (EMC 2353*)
Subfamily: Mid-2010 15" Model ID: MacBookPro6,2
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 500 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
oldturkey03 さんによる
