What is the F26 code?
Washer turns on and starts to add water and then clicks off. The timer works and eventually the F26 starts flashing.
Thank you!
It is a door switch error code, either the connecting wires are loose or the switch is defective. The door switch error code will also be seen if the door is not closed completely. Look fro loose wires first.
このアンサーは役に立ちましたか?
The wires were fine so we are going to replace the door switch. Thanks so very much!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 5,353
what is the f 06 code stand for?rlonadier@windstream.net
bob さんによる
I have a load in the machine and get start there error code F26. How can fix the problem
Kam さんによる
