メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
iPhone 5 service problems after being dropped.
Hi.
So I know a lot about fixing iPhone 4's and 4s's but I've never opened up an iPhone 5 so I am not 100% sure what's wrong with my phone.
I dropped the phone last night hard on the floor and at first all seemed fine. But on closer inspection I noticed the service was dropping in and out constantly... First the 4g icon will disappear and then the actual service on the phone will go into 'searching' and then about 10 seconds later the service will come back on followed by the 4g. And about 10 seconds later it all starts turning off again....
Also, if I make a phone call the service will NOT drop! The service will stay on perfect and clear, but it mainly works on speaker phone. Without speaker phone sometimes I can not hear anything but 'fuzz' and the person on the other end of the call can only hear there own echo...
Can anyone please tell me what needs fixing? How bad is the damage? :(
Thanks in advance :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hello Rin,
So there is a cellular antenna (very similar to the 4 or 4s) that runs from the top right corner and connects underneath the logic board there may just be a loose connection. Also the earpiece speaker is located on the backside of the screen and may just be misaligned. However the i5 is a lot more complex then the 4 or the 4s so proceed with caution.
Earpiece: iPhone 5 のイヤホンスピーカーの交換
Cellular Antenna: iPhone 5のインターコネクトケーブルの交換
Hope this helps!
iPhone 5 イヤホンスピーカーの画像
ガイド
難易度:
中レベル
20 - 40 minutes
iPhone 5 インターコネクトケーブルの画像
ガイド
難易度:
中レベル
5 - 15 minutes
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you. I have now lost speaker when it is on speak phone too. I'm going to take it back to apple first but if they won't replace it then I'll be doing a DIY :) thanks for your reply.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,193
