メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
208回答 すべてを表示
SSD upgrade for Mac Mini Late 2012 2.5GhZ IC 5?
Hi,
Is it possible to upgrade the cheapest mac mini 2012 model too SSD?
Regards
Atle
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Yes, all of the Mac mini's can hold a 2.5" SSD unit in-place of the SATA HD.
If you are thinking of replacing the optical drive then you will need a HD/SSD carrier to hold the drive.
Frankly, I would recommend replacing the HD with a SSHD (HD/SSD hybrid drive) as the better option.
If you are adding the SSD as a second drive then that works as you can then create a Fusion drive with the two drives (HD and SSD).
My home mini is setup with two - 2TB drives as a media server.
At work we use the mini's with hybrid drives. We had some older systems with the optical drive pulled and put in SSD's in place of the optical drives. We later stopped doing this and have gone with SSHD.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi,
Is it possible to add a SSD drive to the factory HDD easily and without loosing the warranty (I mean : the operation must be reversible and invisible) ? My goal is to configure them as fusion drive since the option doesn't exist on their store.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes, you can add in a second drive (HD or SSD) replacing the optical drive. Some models have a SATA port issue so you may not be able to install a SATA III (6.0 Gb/s) drive in place of the optical drive. Instead you'll need to instal a SATA II drive (3.0 Gb/s).
さんによる
I would recommend installing a SSHD vs the dual drive setup as it's just easier and offers almost the same performance.
さんによる
コメントを追加
回答を追加する
Atle さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 1,435
